Please do not get up on the roof and fall off.
Ask around , I am sure you will find some one that is up on roofs with no problem.
The ANT751 is Light Weight and easy to install , the J pole type mount. 2 Screws will hold the antenna in place.
Even a roofer that installs roofs on houses can install this simple antenna.
Handy Man , guys and gals are often up on roofs.
Heating and air conditioning guys and gals are often up on roofs.
Reason: Clarify information and typos.
