Old 27-Nov-2013, 12:44 AM   #2
Flint Ridge
Junior Member Wannabe
First thing I would go back to your data and click on the digital channels only in the current data base. It is a standard radio button. That clears out some noise of channels you probably don't need.
Smarter chaps will be along after awhile. Your NW direction seems the easiest to get. All are UHF except Channel: 6 (6.1) Network: GTN. You could go with just a UHF only.
What channels are you wanting the most? Are the NW stations that are not labeled actual network TV? Seems like the SE has the major networks but the signals will be more challenging. Or are you contemplating use of a rotor?
Flint Ridge is offline   Reply With Quote
