Old 26-Nov-2013, 8:26 PM   #3
Best to have a antenna up higher and in the clear in the directions of reception.
Here are some ways to install antenna/s higher.
Without holes in the roof.
www.ronard.com/ychim.html
www.ronard.com/34424560.html
Use the , ronard(4560)
www.ronard.com/ventmnt.html
A vent mount.
www.ronard.com/tree_adjust.html
The idea is to find a tree that is tall and straight and clear of obstructions of other trees in directions of reception.
It is Ok to cut branches away to improve reception and prevent damage to the antenna.
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , I the solidsignal search box or buy from , www.ronard.com .
www.palcoelectronics.com/pe300.aspx
Last edited by teleview; 26-Nov-2013 at 10:34 PM. Reason: Clarify information and typos.
