Tv antennas do not pull signal out of the air.
Antenna amplifiers do not pull signal out of the antenna.
The best way to increase received signal strength and reduce interference at/from your own , attic , inside of building , roof and building , is to install the antenna above the peak of the roof in such a manner that , attic , inside of building , are not , impeding , obstructing , blocking , reception in the directions of reception.
