Combining Antennas
I have two different antennas on top of my house. They are both pointed in different directions. Since the large antenna 12footer gets all of channels at once except for one, I figured I could stack the two of them. The large one I wanted to use for UHF and smaller one (ANT751) I wanted use for VHF. I tried to use my RCA Amplifier to combine the two since there is a switch in the amp that allows that but it does not help. I need some advice.
1.Is combining the two a bad idea?
2. Should I use a different different combiner instead of the one built into the amp? (if so what do you recommend)
3. Is there a certain distance I should put between the two antennas?
Thanks in advance.
Dan
Mableton, GA
