Old 25-Nov-2013, 4:40 AM   #11
navagator
Originally Posted by teleview View Post
Here are some ways to find information about Tv stations and what Programing is transmitted.
In the , www.google.com or www.yahoo.com , search box , type in variations of the Tv station call sign.
As examples , k23ci , k23ci tv , k23ci-tv , k23ci lp , k23ci-lp , and so forth.
As examples , kcci , kcci tv , kcci-tv , kcci , kcci lp , and so forth.
2 web sites and not the only web sites that will find that have a lot of Pratical and Usefull information are , wikipedia and rabbitears.info .
At the , www.fcc.gov , web site , in the search box at the FCC web site , type in , tv query , tv query broadcast station search .
Can also type this in the , www.google.com , search box
transition.fcc.gov/mb/video/tv.html
In the , Call Sign , box type in the tv station call sign.
Such as , kcci or k23ci .
The FCC web site shows that the Repeater Transmitter are Licensed as , Analog transmitters. Not Digital .
Analog can only transmit one channel of programing.
Digital Tv stations can transmit more then one channel of programing.
Sometimes the originating Tv station , such as KCCI will have only one network on a Analog transmitter , such as CBS.
And can also be two networks on the Analog transmitter ,
By transmitting one network and then the other network , by devideding up the day and night.
So the question is.
Knowing that you will like to watch CBS and Me-Tv.
What Network/s are on the Analog Repeater's (Translators)??
A way to find out is to call the Tv stations on the telephone and have a infoational chat with the engineering department.
My recommendation for the antenna/s , will be based on what is being what Networks are being transmitted on the repeater translators.
KCII channel 8 will be tough to receive reliably.
So if , k23ci , has both Networks , might do it that way , because the signal is closer and stronger.
Thank you for your reply.
From what I understand the translator has been dissolved. Here is a link to NorthPine's Facebook page where I found the information: https://www.facebook.com/northpine/p...51523391561204 .
It may have been in operation though. If it was, I'm afraid I couldn't pull it in.
navagator is offline   Reply With Quote
