Old 25-Nov-2013, 3:36 AM   #3
Because you have the C2V now.
Test reception with the C2V , Above The Peak Of The Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South West , South , South East.
Aim the C2V antenna at about 150 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use the RCA amplifier in the combined single antenna mode.
Set the FM radio Trap the In position.
Do not use your amplifier with the RCA amplifier , using 2 amplifiers will most likely be the cause of reception and distribution problems.
Test reception with 1 Tv connected , No splitter.
If reception goes well with 1 Tv connected and no splitter.
Then for 2 Tv's connected use a , Holland Electronics , HFS-2D , 2 way splitter.
3 Tv's connected use a , HFS-3D .
4 Tv's connected use a , HFS-4D .
Buy the , HFS , splitters at www.solidsignal.com .
Here are some places to buy.
www.solidsignal.com
www.amazon.com
To clear the Tv tuner for a fresh channel scan , do a Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
As Always, trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception , and so do buildings and other obstructions including your own roof and building.
Some and not the only Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflections bouncing around
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type of kind in the directions of reception.
Last edited by teleview; 25-Nov-2013 at 7:50 PM. Reason: Clarify information and typos.
