More questions, need advice please
I have a couple questions already. I was researching, trying to figure out the benefits of 2 separate directional antennas (I believe you said that would be Antennas Direct 91XG aimed at 20° for UHF and an Antennacraft Y10713 High-VHF antenna pointing at about 30° adjusting aim to make reception of both WBNA and WHAS reliable- would this be enough to get the 137° channel 19?) vs a single antenna for both UHF and VHF (UB44or 55). If I understand correctly, the 91XG will pick up the stations 14-69 better and more clear then the HBU44? Does anyone know if the Hbu-44 or -55 pointed at 30° would be able to pick up both the 19/20° and still be able to pick up the 137° VHF channel 19 or is that too big of a range? or if the 2 antenna solution would be better for all the channels? Is there ever interference with 2 or 3 antennas? If I do end up needing to add another antenna pointed south to get channel 19, could I add it if I choose a UBU44/55 or would that cause interference? Ground mount- If I choose 2 antennas, do i need 2 poles, how far apart?
