Old 24-Nov-2013, 11:39 PM   #6
Couch Potato
I've number these responses below so that I can reply to each.
1.A bad antenna and connection and amplifier and power supply.
2. Bad coax and connections.
3. A bad tuner in the Tv.
4. Both bad , antenna and Tv.
5. Substitute antenna and Tv , first one way and then the other.
6.The Tv Must Channel Scan for the Digital Broadcast Tv stations/channels.
#2 I have checked many times. All connections are tight.
#6 This has been done many times.
# 1, 3 and 4 - If this would be so, then why can I still receive channels 50-68? Also why after a few months would channels 2-48 be able to be received again, before losing these stations again?
Couch Potato is offline   Reply With Quote
