The C2V is a well built antenna. I would not offer it as my preferred suggestion in your situation though.
You say that you get between 10 and 20 stations... that suggests that the reliability of some signals is poor. (Y/N?)
If I was stating from scratch I'd use two antennas. The Antennas Direct DB4e (facing about 150°) and Antennacraft Y10713 (pointing at 191°). Mount above the roof, avoiding obstructions if at all possible. I'd suggest the RCA TVPRAMP1R preamplifier which has inputs for each antenna.
The Comscope distribution amplifier may prove unnecessary or even troublesome if the output of the preamplifier is too powerful. Try it, but be prepared to replace it with a passive splitter.
Reason: sp.
