Old 24-Nov-2013, 5:59 PM   #1
tv4jt
Ditching cable in Escondido CA
Just moved to Escondido CA and after reviewing Cox’s pricing decided to see where I could get with an antenna. Went to the local bestbuy and picked up a C2V to see what I could get for stations.
The C2V picked up between 10-20 stations depending on where I placed it. Never intending to keep the C2V from bestbuy (knowing their price isn’t going to be competitive) I began looking at my options online and eventually ended up here.
Found this thread: http://forum.tvfool.com/showthread.php?t=13494 , while I assume most the recommendations would apply to me I noticed his report did not list any channels to the north and all the paths are listed as 1Edge/2Edge while several of mine are listed as LOS.
My reports:
Default: http://www.tvfool.com/?option=com_wr...46ae143745e031
10ft: http://www.tvfool.com/?option=com_wr...46aeabd674a4f9
25ft: http://www.tvfool.com/?option=com_wr...46aee16f97ef7e
So the obvious question, what antennas would work best for me? Should they be mounted as high as possible and at what angles? Would I need more than two antennas if I wanted to pick up the northern channels? If so would it be worth it/ would I then have problems with overlapping channels?
Also while I was looking for the starting point of my cable wiring in my home I found this amplifier.
SVI Digital Subscriber Powered Amplifier SV-A15-4PRS - http://www.shopping.com/svi-commscop...4w==/info?sb=1
Can/should I use this in my installation?
Thanks in advance!
tv4jt is offline   Reply With Quote
