Thank you everyone for the assistance, recommendations and explanations. I've already ordered the CM5016 antenna so at this point, it's worth installing and aiming it to see how it works out. I will post results once that is done. It would be great if those recommending against the L-VHF antenna could post recommendations for those. I'd like to check into those to be ready in case the CM5016 doesn't work out as well as I'd like.
Thanks!!
