Old 22-Nov-2013, 8:06 PM   #16
1. California Tv stations have , construction premits and are using the construction premits to transmit on the VHF low band channels 2 thru 6.
2. The longer reception elements of All channel antennas are desinged to receive the VHF low band channels.
3. And as I stated in the past several times here at Tvfool , the longer reception elements help Reduce Multi-Path off of the mountains that is a Real problem in Califorina.
1. Sure. None are in the Bay area though, so that argument isn't relevant.
2. Correct. That is their ONLY reason for being there.
3. Where is the data that supports that theory?
