Old 22-Nov-2013, 3:51 AM   #2
Disconnect and Remove Flat panel Air antenna and All other parts , power injector , power supply and etc. .
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of , north west , north , north east , south.
Install a Channel Master , CM5016 antenna aimed at about 345 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
A Winegard , DS3000 J pole type antenna mount is a good mount with the CM5016 antenna.
Test reception - Without - a antenna system amplifier.
If when a splitter is installed , and the reception seems a little weak on the weaker Tv stations in the Yellow reception zone of the Tvfool radar plot and channel list.
Install a Winegard , LNA-100 'Boost' antenna system amplifier before any splitter.
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.winegarddirect.com
Last edited by teleview; 22-Nov-2013 at 6:05 AM. Reason: Clarify information and typos.
