Old 22-Nov-2013, 3:19 AM   #8
Some satellite systems will accept and distribute Tv antenna signals and some satellite systems , Will Not .
The best way to avoid problems Tv antenna reception and distribution is to , Disconnet and Remove satellite system components such as and not limited to , multi-plexers , diplexers , splitters , couplers , amplifiers , power injectors , power supply's , receivers and etc. , so that only the antenna system components make up the antenna system .
Yes is Ok to use satellite system coaxes for the antenna distribution.
