Old 22-Nov-2013, 2:48 AM   #1
strav
Advice needed for Bay Area antenna setup
Hi all,
I'm looking for a recommendation for my setup. I'm currently using a roof mounted Winegard FL6550A FlatWave Air Outdoor antenna (built in amplifier), with about 60 feet of cable (no splitters yet) to a HDHomeRun tuner. Antenna is currently pointed at 318 degrees. I'm trying to get at a minimum the following stations:
KTVU
KRON
KPIX
KGO
KNTV
TV Fool Report: http://www.tvfool.com/?option=com_wr...46aebd9a8e7b23
Currently, KTVU, KGO and KNTV work well. I'm able to get a lock on KPIX, but I get a fair amount of pixelation every minute or two. I can't seem to pick up KRON at all.
Ideally, I will eventually add a second HDHomerun Tuner and also hook up the 2 TV sets. 4 connections in total.
Any suggestions on how to pick up KRON and improve the signal from KPIX?
Thank You!
strav is offline   Reply With Quote
