As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception , and so do buildings and other obstructions including your own roof and building.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflecting Tv Signals Bouncing Around.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Memu and select , DTV Channels ~ Antenna Channels ~ Air Channels~ .
Scan for channels.
Reason: Clarify information and typos.
