Old 20-Nov-2013, 2:41 AM   #2
The Current Tv channels that are being transmitted and received in the , USA , Canada , Mexico , are
VHF low band channels 2 thru 6 .
VHF high band channels 7 thru 13 .
UHF band channels 14 thru 51 .
Your location has receivable channels in the VHF high band and UHF band.
A ANT751 antenna is designed to receive the VHF high band channels and UHF band channels.
The antennas you have named are designed to receive the UHF band.
A Simple reception situation.
Above the roof in such as manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , north west , east north east , west , south west , south south east .
Install a ANT751 aka ANT751R antenna aimed at about 323 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
The reception at your location is strong signal strength.
No antenna system amplifier is required.
For 3 Tv's connected use a simple common 3 way splitter.
Home Depot and Lowes can have the ANT751/R in stock in the store no matter what the Home Depot and Lowes web sites say.
Here are more places to buy antennas and etc. .
www.solidsignal.com
www.amazon.com
Last edited by teleview; 20-Nov-2013 at 4:19 AM. Reason: Clarify information and typos.
