Old 19-Nov-2013, 10:50 PM   #23
No advantage of signal strength by going higher then 25 feet antenna height above ground.
To reach out for reception of
http://en.wikipedia.org/wiki/WHAG-TV.
REAL Digital UHF channel 26.1 , (virt) virtual number (25.1) , NBC .
http://en.wikipedia.org/wiki/WWPB.
REAL Digital UHF channel 44.1-2-3 , (virt) virtual number (31.1-2-3 , PBS channels.
http://en.wikipedia.org/wiki/WWPX.
REAL Digital VHF channel 12.1-2-3 , (virt) virtual number (x) ION Television channels.
Above the peak of the roof in such a manner that the roof and chimney and building are not , obstructing , impeding , blocking , reception in the directions of , east south east , south south west.
Install a Winegard HD7698P antenna aimed at about 124 degree magnetic compass direction , a in between aim direction for reception of those 3 Tv stations to the , east , south east.
The HD7698P antenna is designed to receive , VHF high band channels 7 thru 13 and UHF channels 14 thru 51.
The signal strengths are Very Weak , so install a , Ultra Low Noise antenna system amplifier.
Install a , http://www.kitztech.com ,
Model KT-200-COAX TV Antenna Booster Remote Power -Coax Fed.
The remote power amplifier provides flexibility of use , to install the amplifier unit inside or outside.
Recommend the setup Test reception be only 1 Tv connected. No splitters.
If all goes well , can add a 2nd or 3rd Tv with a
Holland Electronics , HFS-2D , 2 way splitter , or , Holland Electronics , HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com
http://www.amazon.com
http://www.winegarddirect.com
www.kitztech.com
W23DR-D Real UHF channel 23 , and , W07DN-D Real VHF channel 7 .
Are both West Virgina PBS. http://en.wikipedia.org/wiki/WNPB-TV
As a Test of reception can aim the HD7698P antenna at those 2 Tv stations and scan for channels for the one that is received the best.
Last edited by teleview; 20-Nov-2013 at 2:14 AM. Reason: Clarify information and typos.
