The long pole up the side of the house and extendeds above the peak of the roof is Ok.
As to the chimney , it's Ok if the chimney is not in the path of reception so the chimney does not reduce or block reception.
I sure would like to have a look at those 40 and 60 foot broadcast Tv antenna heights above ground , even if you will not be installing the broadcast Tv antenna that high.
As to the Eliptical satellite dish , it is used to receive more then one satellite with one reflector dish.
There will be more then one circular shaped receiving antenna out in front of the dish or a Eliptical shaped antenna out in front of the dish that is devided into sections that does the same as separate antennas out in front of the dish.
Reason: Clarify information and typos.
