Old 19-Nov-2013, 5:51 AM   #1
rm6p
Antenna help needed in San Diego
Help for someone new to over air broadcasts. I cannot chase the audio problem down on channel 8.1 KFMB.
I installed an RCA ANT751 at the peak of the house (about 15 ft off the ground). At 130 deg magnetic, I can receive all required channels with great pictures but have a serious audio problem with channel 8.1 KFMB and a slightly less problem with KSWB 69.1. According to the TV, signal strength is very strong at between 70-80 for channel 8.1. The sound cuts in and out so much you cannot watch that channel. I have tried all points between 130 deg through 230 deg with no difference. I added an Antennacraft 10G201 pre amplifier with FM trap with no difference. I tried and returned a Channel Master CM-2016 with and without the pre-amp with no improvement. The RG6U coax is temporarily run directly from the antenna through the patio door to the TV in one piece. TV is a Sharp LC-52D64U with the latest firmware installed.
http://www.tvfool.com/?option=com_wr...46ae68b095da46
Must have channels
KFMB 8.1
KGTV 10.1
KPBS 15.1
KNSD 39.1
KUSI 51.1
Like to have channels
MeTV 8.2
Movies 13.3
KSWB 69.1
From standing on the roof it looks like I am behind a stand of trees a few miles away and in a slightly lower spot.
I would appreciate any suggestions including starting from scratch. I have to get these channels as solid as possible before cutting the cable.
Thank you
rm6p is offline   Reply With Quote
