Old 18-Nov-2013, 8:57 PM   #7
Recommend install 1 antenna for now and see how reception goes.
Might require a second antenna later.
The Current Tv stations/channels that are being transmitted and received in the , USA , Canada , Mexico , are
UHF channels 14 thru 51.
Your location has receivable Tv stations/channels in All 3 Tv bands.
WMC , channel 5 , NBC , is your only receivable NBC station.
The Signal Strengths of All Tv stations/channels are weak signal strengths at your location and add to that the trees obstructions and a Large All channel antenna is required.
The Winegard HD7084P All channel antenna is a better antenna then the Winegard HD8200U antenna.
The HD7084P antenna has more low channel band 2 thru 6 , antenna gain , and better flatness of response across all the Tv channels.
Install the HD7084P antenna above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South , South West , South East.
Aim the HD7084P antenna at about 180 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html .
Here are some Strong and Sturdy above the roof antenna mounts.
www.ronard.com/909911.html
Install the , ronard(911) , 5 foot tripod antenna mount.
www.ronard.com/Tripods%200703/4712.html
10 foot tripod antenna mount.
www.ronard.com/34424560.html
Install the , ronard(4560) , eave antenna mount.
www.ronard.com/ychim.html
Measure around the Chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
www.solidsignal.com
www.amazon.com
www.winegarddirect.com
www.channelmasterstore.com
Install a Channel Master CM7778 preamplifier.
For 2 Tv's connected use a , Holland Electronics, HFS-2D , 2 way splitter.
Buy the HFS splitters at , www.solidsignal.com
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception in the directions of reception and so do buildings and other obstructions in the directions of reception.
Some and not all of Negative Effects are
Absorbing, Blocking , Reception
Multi-Path Reflections bouncing all around
The Best Pratice is to install the HD7084P antenna at a location that has the least amount to no-amount of obstructions of any type or kind in the directions
of reception. South , South West , South East.
Last edited by teleview; 19-Nov-2013 at 4:00 AM. Reason: Clarify information and typos.
