One of Tvfool reports is at 10 feet antenna height and the other is at 25 feet antenna height , if the reports are made with the Correct address / location , the signal strengths improve at the 25 foot antenna height.
Please make and post Tvfool reports using the correct address / location , at 40 and 60 feet antenna heights.
The FTA transmissions and reception , does not change , as those using the service come and go and then possibly return at a later date.
The technology improves and changes as time goes by so there is change in that respect , however a new receiver Is Not required as the Programing providers come and go etc. .
There is No catch , There is No trick , to FTA.
The transmission and reception of FTA is made up of basic standards.
With FTA , it helps if one is a flexible thinker.
There are variations added to the basic standards of FTA.
Might help to think of the situation this way , before stereo records , were mono single audio channel records , a mono audio record player will play a stereo record , however not in stereo , and the other way around.
Reason: Delete off topic comments
