Signal can flow either direction in coax cable... But signal from an antenna needs to arrive at the input side of any splitter or amplifier. This means that you can use any one piece of coax as you please, but you'll need to connect all accessories with the correct orientation.
Also, it's extremely important that the cable company connection be disconnected from any coax used for OTA signals. Even if you have not paid a bill to the cable company, it's possible they are feeding some signal into your house. If so, that signal will radiate into the air via your antenna if you get the two systems connected to each other. That will cause interference to licensed radio services such as police, fire & aviation.
