Old 17-Nov-2013, 2:19 PM   #7
Jockamo
Please consider testing reception outside, preferably from the roof-top. The C290 is probably enough antenna... If not for the signal degradation caused by the attic/roof construction.
Is there another antenna that would be better suited for my situation if I were to mount outside? I don't mind buying a different antenna if it will increase my chance of success. Do you have any opinions on this antenna?
http://dennysantennaservice.com/hd_s...enna-html.html
Also after finding no signal on my 3rd tv(long coax run) I installed
RadioShack® High-Gain HDTV-FM Signal Amplifier
Model:
15-259
With the gain all the way down I get a good picture on all TV's. is there any longevity issues with RadioShack equipment? Like the antenna I would like to do it right the first time if installed on the chimney. The location is not easily accessed and I don't want to have to call for return service.
Jockamo is offline   Reply With Quote
