Old 17-Nov-2013, 9:10 AM   #4
fishnugget
Originally Posted by StephanieS View Post
Hi fishnugget,
Your radar plot, while not down to your specific address, gives a reasonable indication that you are in a good place for reception.
I would suggest your rerun your radar plot with the specific address and the antenna height you intend to operate at.
That said, a cursory examination shows you don't need a lot of horsepower. You are close and if installing on your roof with a clear line of sight and if your radar plot at your address is as good as your block level, a RCA ANT751 ought to do the job nicely.
I would point it near magnetic 310 running a single line of coax into your TV. You don't specify your situation, if you want more run to more than one TV or not. If you are running a long run and/or splitting the cable to different TVs you may need some additional equipment.
That said though, the ANT751 is nice early candidate for your situation.
Thanks Steph,
I updated my report, I am so new at this, I have not figured all the terminology but if the signal is good enough I would run it to multiple TV's. I think I would first try 1 TV and see how it goes from there. But thanks for the antenna recommendation. It looks like I will have a hard time getting CBS and Fox, they are gray, no?
fishnugget is offline   Reply With Quote
