Test reception , connect a New continues length of coax to the DB8e antenna and run the New continues length of coax through a open door or window direct to 1 Tv.
The connections part of the DB8e , the transformer inside the box that connects the metal receiving elements of the antenna to the coax might be defective.
Also , As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception in the directions of reception
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflecting Tv Signals Bouncing All Around
And buildings and other obstructions in the directions of reception including your own roof and house in the directions of reception.
The Best Practice is to install antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building in the directions of reception.
Reason: Clarify information and typos.
