Old 16-Nov-2013, 9:16 PM   #7
aamitabh
No success with 26.1
Before I install it in the attic or the roof, I tried to mount the antenna to pool rod and raised the antenna to about 20 feet inside my bedroom. I get no signal on channel 27 (26.1). I only hit 14.1 and then it jumps to 36.1 which makes sense.
To test out a bit more I put the ChannelMaster cm-3412 preamp as well to no avail.
Do you think that I would see a huge difference between 20 feet height versus raise it to the rooftop (adding another 15 feet).
Feeling a bit discouraged right now.
Cheers.
aamitabh is offline   Reply With Quote
