Old 16-Nov-2013, 7:01 PM   #5
The terrain between your location and the San Fransisco transmitters is quite a challenge. Keep experimenting with antenna placement (including both high and low locations).
Consider the Antennacraft Y10713 for H-VHF.
I presume the CM-3412 is some distance from the antenna... An RCA TVPRAMP1R is designed to be exposed to the elements, so it can be mounted at the antennas where it can be most effective. The RCA preamp also has inputs for separate UHF and VHF antennas.
