Old 15-Nov-2013, 5:33 AM   #4
The provided tvool report is the default 10 feet antenna height.
To see if reception signal strengths improve at higher antenna heights please make 3 Tvfool reports at , 25 , 40 , 60 , feet antenna heights.
Please use the Exact address to make the reports.
Do not delete the first Tvfool report that is the default 10 feet above ground antenna height.
If your Exact address does not work to make the Tvfool report then go to the Tvfool home page and click on >>Start MAPS<< , move the pointer to your Exact location , enter the antenna height and click on the , Make Radar Map , button .
Last edited by teleview; 15-Nov-2013 at 6:46 AM. Reason: Clarify information and typos.
