Ensure that you have both panels of the DB8e aligned in parallel and aimed at Mt San Bruno. Add a capable, sensitive, medium gain pre-amplifier. Hunt for a mounting spot where you can catch your desired channel without loosing others.
Also since DB8e is only a UHF antenna what do I do for VHF channels?
Add a high-VHF antenna.
KNTV is the only VHF-only station if SF. KGO runs a UHF 35 translator from your south which may or may not come in with the DB8e focused to the west.
