Old 13-Nov-2010, 4:50 AM   #8
whatsgoingonhere
HI John,
Thanks for taking the time! A few things: The antenna is outside and facing south. The digital tuner is integrated into the tv so no digital converter box is hooked up.There are some building on the way, but most digital channels are showing ok with some pixelation now and then the meter in the tv shows around 70 for most channels. The antenna is connected to the house wiring and from there the tv is connected to the wall outlet. I don't have an amplifier although I've thought about.
I don't know if this is relevant or not but channel 47 shows in the analysis farther down the list than either 5 or 38 but while 47 is crisp and good 5 is snowy and 38 just doesn't show up at all. Maybe I should get an amplifier. Do you think that would help?
Thanks again for the help.
whatsgoingonhere is offline   Reply With Quote
