Old 13-Nov-2013, 4:55 PM   #3
A Very Simple Reception Situation That Will Receive , 20 Plus , LOS=Line Of Sight , Easy to Receive , Digital Broadcast Tv Stations.
And even more Digital Tv Channels.
Above the roof in such a manner that the reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South West / South / South East , North / North West.
Install a ANT751 antenna aimed at about , 150 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html .
A antenna system amplifier is not required.
For 1Tv connected use No splitter.
For 3 Tv's connected use a simple common 3 way splitter.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv Stations Channels , often named the ~ DTV Channels ~ Air Channels ~ Antenna Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Air Channels ~ Antenna Channels.
Scan for channels.
Home Depot and Lowes can have the ANT751 in stock in the store , no mater what the Home Depot and Lowes web sites say.
Here are some more places to buy antennas and etc. .
www.solidsignal.com
www.amazon.com
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception.
Here are some Negative Effects.
Absorbing , Blocking , Reception
Multi-Path Reflecting Tv Signals Bouncing Around
And also buildings and other obstructions in the directions of reception.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind on the directions of reception.
Last edited by teleview; 27-Nov-2013 at 2:36 AM. Reason: Clarify information and typos.
