combineing antennas
Thank you for responding.
I currently have two identical generic yagis; they are vertically stacked approximately 1 meter apart. I may replace them with name brands if I can prove they will improve a reasonably good reception. I am using an RCA splitter reversed to combine them. They are grounded from the shell of the splitter. I have identical lengths of RG6 from the antennas to the splitter/combiner. I have them aimed 90 degrees from each other to pick-up stations in two large sources. I run RG6 from the combiner to the television. On an average day I will get all the LOS channels plus some unlisted channels. Occasionally I lose some of the more distant channels and would like to reduce those occasions. I am also considering two more yagis to point opposite to the existing ones to cover some fringe are locations.
I am interested in your thoughts.
cheers
