Your TVFool plot suggests that, as long as there are no immediate signal obstacles such as trees or buildings in your signal path back to Denver, reception should be moderately simple with a medium-sized 7-51 antenna. If you have other requirements, then perhaps a rotor with a larger antenna might be suggested.
You will have to more clearly define your wants and needs to see what is necessary.
