Tv Reception
The best way to do coax or phone wiring is what is some times called 'home run'. As a example think about a base ball field. The batter hits the ball from home base , out to some where out in to the grand stands , the same thing happens with the coax or phone wire , from the main location (home base) the wire goes out to somewhere in the house , and then an other wire goes out from the main location to some where in the house , and an other wire goes out from the main location to some where in the house. . At the main location is the coax splitter or coax distribution amplifier , or for phone wiring the 'punch down' connection block. This is the best method of wiring because it allows for control of all the wiring at the main location and the coax wiring can be connected in different ways at the main location. As an example but not the only example lets say that a DVD player is located in a room and you will like to watch the dvd in an other room , what you do is connect the two coaxes together with a F-81 barrel at the main location. So now as you think about it you understand that having the wiring at a main location and the wires go out to each location is a better way to do communications wiring.
