Old 13-Nov-2013, 8:28 AM   #2
The CS4 is a real fine UHF channels 14 thru 51 antenna , however not good receiver of the VHF high band channels 7 thru 13.
For reception of the weak signal strength channel 9 CBC Tv transmission and other VHF high band tv transmissions at your location , install a , www.antennacraft.net , Y10713 VHF high band channels 7 thru 13 antenna.
Connect the CS4 antenna and Y10713 antenna together with a , EU385CF , UHF/VHF diplexer combiner.
Aim the Y10713 antenna at about 141 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antennas/pointing/pointing.html
Seperate the CS4 and Y10713 antennas buy about 3 feet on the same mast , put the CS4 above the Y10713 .
Looks like , www.amazon.com and www.mcmelectronics.com , have the EU385CF , in stock.
Test reception Without a antenna system amplifier.
And can also Test reception with a Winegard , LNA-200 'Boost' XT antenna system amplifier.
If you can , install all parts of the amplifier , power supply , power injector , preamplifier , before the splitter.
If not , then use a power passing splitter.
Such as and not limited to the , Holland Electronics , HFS-2D , 2 way splitter.
Buy the HFS splitter at , www.solidsignal.com
For the Y10713 antenna , www.solidsignal.com , www.amazon.com , www.antennacraft.net .
For reception of the CBC , the Y10713 antenna will be installed Above the Peak of the Roof in such a mannner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of reception.
And Yes the CS4 is up above the roof with the Y10713 antenna.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , buy typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com
Last edited by teleview; 14-Nov-2013 at 7:06 PM. Reason: Clarify information and typos.
