Old 13-Nov-2013, 2:26 AM   #1
davidkjohnson
Combining two Antennas - Balun Polarity
When combining the two antennas do you reverse the leads on one at the balun on the antenna so they are in series or do you keep them the same. Does this matter if they are pointing in the same direction or offset by 90 degrees?
I think I am going to reverse the leads on one and see what happens.
davidkjohnson is offline   Reply With Quote
