Thread: Getting Fed Up
Old 13-Nov-2013, 2:07 AM   #4
pawoodbutcher
I agree that the 8200 has more Low VHF than I need, but when compared to the 7698, the UHF specs are the same. Or at least very close. Maybe I don't know what I am talking about.
I did meter the output of the wall adapter plug when it was unplugged from the power injector. Now that you brought it up, the no load voltage would be higher. Absolutely true.
Back to the issue, the system used to work very well. Something happened.
If my amp is inexpensive, I am all ears to getting a good one that will last.
The problem is either the digital boxes or the amp.
pawoodbutcher is offline   Reply With Quote
