Thread: Getting Fed Up
Old 13-Nov-2013, 1:09 AM   #3
tomfoolery
Originally Posted by pawoodbutcher View Post
A month ago, I metered the output of the power supply at 20.x volts. Supposed to be 12. Did it yesterday, 20.4 Volts. I thought this to be odd, but I have no baseline to compare it to when it was new.
Small, inexpensive power supplies commonly read much higher voltage under no-load or less-than-design-load conditions than they will when driving the load they're designed for. If the amp was disconnected, that could explain the difference. If it was connected, then there may be a problem with the amp.
