Old 13-Nov-2013, 12:07 AM   #3
I'm currently looking at a Channel Master CM 5016. Looking at the spec's it appears that it should work for me. It's claiming a 60 mile range for the low VHF channels, so it might even work in the attic for me.
Is the 5016 a good choice?
No, you're probably looking at the wrong thing because the CM2016 is a high-VHF/UHF (7-69) antenna with no specifications for low-VHF.
GUM's recommendation is spot-on.
