Old 12-Nov-2013, 9:13 PM   #5
If you have no view to the south...
It sounds as if you will need quite a bit more antenna... Enough to get a bounce off a building to the north of you.
If not for the obstructions, the C2-V would be an appropriate selection. At this point, you know that signal is available, but appears to be a mix of direct and reflected path copies...
I would consider stepping up to the largest 7-51 or 7-69 antenna that would fit in the available space. If i could find the space to accommodate it, the Winegard HD7698P would not be overkill. This is going to require some experimentation and patience to find the right aim point.
