Old 12-Nov-2013, 9:26 AM   #2
The Current Broadcast Tv Channels the are Transmitted and Received in the , USA , Canada , Mexico , are ,
VHF low band channels 2 thru 6
VHF high band channels 7 thru 13
UHF band channels 14 thru 51 .
Your location has receivable Digital Broadcast Tv stations/channels in all 3 Tv channel bands .
Recommend install a All Channel Antenna .
Install a Channel Master , CM5016 All channel antenna aimed at about , 354 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna .
Yes you can start with the CM5016 in the attic .
Install a Winegard , LNA-100 'Boost' antenna system amplifier before any splitter/s .
If reception situations happen in the attic that are not resolvable with location and aim adjustments in the attic .
Then move the CM5016 All channel antenna to above the Peak of the Roof in such a manner that the roof and attic and building are not , obstructing , impeding , blocking , reception in the directions of , north west , north , north east , east , south east .
Install the LNA-100 'Boost' amplifier before any splitter/s .
For 4 Tv's connected use a simple common 4 way splitter.
A Winegard DS3000 J pole type antenna mount works Ok with the CM5016 antenna .
Here are some more above the Peak of the Roof antenna mounts .
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
www.solidsignal.com
www.amazon.com
www.winegarddirect.com
www.ronard.com
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Air Channels ~ Antenna Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna .
Some Digital Tv,s will Automatic channel scan for cable Tv channels .
DO NOT channel scan for cable tv channels .
Go into the Tv Setup Menu and select ~ DTV Channels ~ Air Channels ~ Antenna Channels .
Scan for channels .
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception
Here are some and not all Negative Effects
Absorbing , Blocking , Reception
Multi-Path Reflecting Tv signals bouncing all around
And buildings and other obstructions also have a Negative Effect on Broadcast Tv Reception in the directions of reception , including your own , roof , attic , building .
The Best Practice is to install the CM5016 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building .
Last edited by teleview; 12-Nov-2013 at 9:49 AM. Reason: Clarify information and typos.
