Old 12-Nov-2013, 12:46 AM   #36
Damon459
Today I received and installed my AntennaCraft Y10713 and wanted to post my results. KPAX-DT 65%, KECI-TV 65%, KUFM-TV 40%, all based on my tv's signal meter. Now I was able to get KUFM-TV at 70% is I raised the antenna higher but lost all others in the process. Interestingly enough in order to get all channels I'm pointed at 189 degree's. When pointed at the Azimuth listed on my tvfool report I get nothing, I'm assuming this is due to my 2EDGE signals. My next step which many not happen until spring is to add a UHF antenna in the hopes of getting KTMF-DT, of course by then they should have a new owner who will hopefully correct their signal problems. I know people even in town that can't get signal without a large rooftop Antenna, because they use a directional antenna pointed north and located north of town. So I want to say thanks to those who helped me during this process and I'm glad I took the advise on the AntennaCraft Y10713 it works very well and was very affordable from solid signal.
Damon459 is offline   Reply With Quote
