Thread: Lightning Fix
Old 12-Nov-2010, 8:59 PM   #17
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
Originally Posted by westom View Post
Every wire inside every incoming cable must make that short connection to earth before entering. You reroute any cable that does not.
A problem created because too many installers only understand code; do not learn what is also required for surge protection. A utility explains how to kludge a solution only if the superior solution cannot be implemented. How to enlarge a single point ground so that every incoming wire still makes that necessary short connection:
http://www.duke-energy.com/indiana-b...ech-tip-08.asp
I'm saying that there is no physical way to "make that short connection" that you are referring to. Something tells me I'm not the only one, either.
And I am sorry, but I don't understand what your second paragraph says.
~Joe
Avoid Sears Home Improvement!
jp2code is offline   Reply With Quote
