Old 10-Nov-2013, 1:23 AM   #9
Attics Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Try locating the antenna at different locations all over the attic try adjusting aim of the antenna in the attic.
The Digital Broadcast Tv reception is Very Strong Signal Strength , do not use a antenna system amplifier in the attic.
The first digital channel of the Tvfool report KCPT-PBS , is High Lighted with Red , this means the signal is over the top strong.
A amplifier will most likely over load and be the cause of bad reception of one or more channels.
For better reception install a Channel Master CM4228HD antenna above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , West , North West , South West.
The Winegard DS3000 , J pole type antenna mount works Ok with the CM4228HD antenna.
Here are some more antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com
Here are some places to buy antennas and etc.
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.winegarddirect.com
A antenna system amplifier is not required.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception ,
Some and not the only Negative Effects are ,
Absorbing , Blocking , Reception.
Multi-Path Reflecting signals bouncing around.
and so do buildings and other obstructions including your own , roof , attic , house.
The Best Practice is to install the CM4228HD antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Digital tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 11-Nov-2013 at 7:29 PM. Reason: Clarify information and typos.
