Old 9-Nov-2013, 11:19 PM   #8
Tower Guy
Originally Posted by brichar62 View Post
I re-aimed the attic antenna and got identical results. Is this some type of interference?
You have signals from multiple directions. Yet mis-aimed antennas can cause what you are observing and you can't aim a single antenna in all those directions at once. The optimum direction for you will be due west and the optimum antenna is a UHF only with a wide pattern. (Antennas Direct C-2 or DB-2)
To aim the antenna perfectly, try for the strongest signal on WDAF.
