Old 12-Nov-2010, 10:47 AM   #3
linter
Originally Posted by John Candle View Post
Sounds like you have the cable tv and the antenna connected together and then not connected and then connected and then not connected and etc.. I suggest you arrive at a understanding of how the coaxial wiring is run. Is the coax run as , loop , home run , or combination of both? . Do Not connect both the Tv antenna and the Active cable tv at the same time on the same coax. . Loop type wiring is also known as daisy chain.
Is there any easy way to tell which type of wiring I've got? A lot of it is out of sight. And then, once I know, what can I do about it -- i.e., is there a site with instructions to help me fix it?
update: okay, so i've determined i've got the loop type of wiring. will investigate further and report back ....
linter is offline   Reply With Quote
