Old 9-Nov-2013, 4:48 AM   #3
Exclamation +=>
A Simple reception situation that will receive Many Digital Broadcat Tv stations/channels.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception to the , North West , North , North East , West , South West , South.
Install a Antenna Craft HBU44 antenna aimed at about 18 degree magnetic compass direction.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
For 1 Tv connected , a antenna system amplifier will most likely not be required.
For , 2 , 3 , 4 , Tv's connected install a Winegard , LNA-100 'Boost' antenna system amplifier , before the splitter.
For 4 Tv's connected use a simple common 4 way splitter.
www.solidsignal.com
www.amazon.com
www.antennacraft.net
www.winegarddirect.com
www.ronard.com
This next information is Very Important Tv channel scaning information.
The Digital Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels.
The , ATSC , aka , 8VSB , Digital Broadcast Tv Channels.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Do Not channel scan for Analog broadcast Tv stations/channels , only.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels.
Often named the , DTV Channels ~ Air Channels ~ Antenna Channels , in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels.
Scan for channels.
As Always , trees and tree leaves , plants and plant leaves , in the directions of reception have a Negative Effect on Broadcast Tv reception.
Here are some and not all of the Negative Effects.
Absorbing , Blocking , Reception.
Multi-Path Reflecting Tv signals bouncing around.
And so do buildings and other obstructions including your own roof and house.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Last edited by teleview; 9-Nov-2013 at 7:44 AM. Reason: Clarify information and typos.
