Thread: Antenna help
Old 8-Nov-2013, 8:27 PM   #2
Exclamation +=>
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , West and East.
Install a Winegard , HD7698P antenna aimed at about 270 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
www.ronard.com/909911.html ,
The , ronard(911) , 5 foot tripod antenna mount.
www.ronard.com/Tripods%200703/4712.html
The 10 foot tripod antenna mount.
www.ronard.com/34424560.html
The , ronard(4560) , eave antenna mount.
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
Test reception without a antenna system amplifier.
After some time goes by , and you think that antenna system amplifier might help with the weaker signal strength Tv stations
that are in the Red Reception Zone of the Digital Current Plus Pending Applications Included Channel List of the Tvfool Channel List
then install a Winegard , LNA-100 'Boost' amplifier , before any splitters.
For 3 Tv's connected use a simple common 3 way splitter.
www.solidsignal.com
www.amazon.com
www.winegarddirect.com
www.ronard.com
As always, trees and tree leaves , plants and plant leaves , have a Negative Effect on broadcast Tv reception
Absorbing , Blocking , Reception ,
Multi-Path Reflecting signals bouncing around ,
and so do buildings and other obstructions including your own roof and house.
The Best Pratice is to install the HD7698P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv's Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv stations/channels , often named the , DTV Channels ~ Air Channels ~Antenna Channels , in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels .
Scan for channels.
Last edited by teleview; 10-Nov-2013 at 6:37 PM. Reason: Clarify information and typos.
